48 minutes ago, Matthew Waring said:
I keep shadowplay on all the time and even with bf1, i dont see any decrease in performance.
You're right, shadowplay doesn't decrease performance, not at least in terms of frame drops. But it can cause games to go weird. Need for speed 2015 and gta v. Gta v is stutter and need for speed you fall through the map.
Did you try disabling or uninstalling shadowplay to see if it solved your first issue?
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
https://linustechtips.com/topic/716297-gtav-pc-problems/page/2/#findComment-9145921
I will try it next time im available
https://linustechtips.com/topic/716297-gtav-pc-problems/page/2/#findComment-9147681
Ok, it should solve the stutter. As for the other problem regarding passengers going crazy, sounds just like gta haha.
https://linustechtips.com/topic/716297-gtav-pc-problems/page/2/#findComment-9147690
