Battlefield 4 help
Go to solution Solved by TheRuke,
Is the Processor hyperthreaded? If it is, BF4 now utilizes 4 cores and it's better if you have 4 physical cores. Have you updated Drivers for your GPU? If not, you really need to.
hello people of linus forum,
i am needing help with battlefield 4. on battlefield 3 ultra settings i get 80fps however on battlefield 4 everything on the lowest it can be i get 1-4fps. plz help
System components:
8gb of ram
Nvidia GTX 660 ti with 2 gb ram
running windows 7 home premium 64bit
AMD FX-4100 Quad-Core processor 3.60 GHz
https://linustechtips.com/topic/71620-battlefield-4-help/
Install the latest drivers and patch the game to the latest version.
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/71620-battlefield-4-help/#findComment-980694
Update your drivers to the latest beta driver probably will fix this. I have a 660ti and when i played the beta i got like 50 fps on highest settings so something must be very wrong if you have updated your drivers.
https://linustechtips.com/topic/71620-battlefield-4-help/#findComment-980695
| Case: NZXT Tempest 210 | CPU: Intel Core i5 3570K @ 3.9 Ghz | GPU: ASUS ROG STRIX GTX 1070 | RAM: Crucial Ballistix Tactical 8GB |
| Mouse: Zowie FK1 | Monitor: Acer 21.5' | Keyboard: CoolerMaster Stealth w/ Brown Switches |
#KilledMyWife - #LinusButtPlug - #1080penis
https://linustechtips.com/topic/71620-battlefield-4-help/#findComment-980697
AMD dont have Intel Hyperthreading.
But yeah i agree with what everyone says Update your driver to your latest beta drivers.
Also remember that BF4 is a step up from BF3, requiring 3GB of VRAM on "recommended" and your card only has 2GB.
Quack 🦆
https://linustechtips.com/topic/71620-battlefield-4-help/#findComment-980735
I derped on Hyperthreading.
Good, try to stay up to date in the future.
I do have 2GB but I'm fine. I get like 50FPS. I think the "3GB reccomended" is a push for the new AMD GPUs.
https://linustechtips.com/topic/71620-battlefield-4-help/#findComment-980757
HAHA  np I too often stay up late and post pure rubbish  :rolleyes:
I think perhaps if you have 2GB VRAM that your PC might have to start using Virtual Ram, being slower to access that the VRAM on the card it will mean you would drop a few frames but nothing major I doubt. (don't quote me on this though its only a thought)
Quack 🦆
https://linustechtips.com/topic/71620-battlefield-4-help/#findComment-980967
