I am building my first pc but I would like to liquid cool because I like doing new things but I need help getting the parts necessary to do so can you guys tell me what to get here is my build. I'm not sure if I should go with hard or soft tubing.
PC Build
Ryzen 1800x
Asus Strix 1080ti
G-Skill Trident z RGB 32gb 3200mhz
Gigabyte K7 motherboard
NZXT Kraken x62
EVGA Supernova P2 850w
Phanteks Enthoo Evolv ATX TG
SAMSUNG 960 EVO M.2 1tb
Seagate Barracuda 3tb
Gigabyte WiFi and Bluetooth Card
x3 NZXT Aer RGB Fans
NZXT Hue
https://linustechtips.com/topic/715260-help-on-custom-loop/
You've completely screwed up with the monitors. Get 2 or 3 1440p Monitors all at the same refresh rate.
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117534
Why are there 3 different monitors?
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117540
Reason I have the 1080 on the right it for console gaming the x34 is for editing and playing games and left is for games that hit more than 100fps
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117545
Fair enough with the 1080p monitor, but just get 2 1440p 100Hz monitors for the Gaming and Editing...
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117550
I guess I can just switch the left back to a 1080p but I edit more than 3 videos a day do the ultra wide would help and I figure the ultra wide isn't very good for gaming cause I was told 100fps isn't very pleasing and that it doesn't even oc to 100hz that's usually they max out at 95
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117554
Is the ultra wide not worth it for editing or something?
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117565
Here's what you should do:
Find 2 1440p monitors at 100Hz and add them to your list.
Get the 1080p monitor you were talking about.
It doesn't matter how many videos you edit a day, you'll only be editing one at a time unless you're superman.
100fps isn't pleasing? I have a 60Hz monitor and it works fine and I find it pleasing enough...
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117567
Alright now what about the loop how do I go about doing that?
https://pcpartpicker.com/list/Gy6jvV
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117577
So the main parts you'll need will be water blocks and radiators. Those will be the most expensive single items you buy. Fittings will add up quickly but individually are cheap(ish) and then of course the tubing. EKWB has a fancy little configurator that you can use to get the idea of the parts you need. I highly recommend EK, quality products and service. (In my experiences.) Stay away from Koolance though, I have had bad experiences and it was very unpleasant to get everything sorted out. A crucial mistake I made when doing my first custom loop was I bought a generic water block for 2 1070 STRIXes rather than a STRIX specific block.
Hope this helps answer some of your questions!
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117583
Should I do soft or hard tubing
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117593
Soft, hard tubing is much harder and more expensive and very time consuming and frustrating. I haven't even dared myself yet after watching some videos.Linus did a hard tube loop if you want to watch that video for reference.
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117604
Definitely soft tubing if it's your first time, or even your second or third.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117722
I knew about the ekwb custom config thing is this everything I would need https://www.ekwb.com/custom-loop-configurator/shared/oW5867f78fd5020
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117734
I would rather get other fans and liquid coolant besides the stuff they provide and would I need more tubing and anymore fittings?
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117744
If you can fit another rad in there both in terms of case and budget, I would try to do so, just so you can run the fans lower. Other than that it looks good although I would add another 3m of tubing to be safe.
Prior Build Log/PC:
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117856
What's a good case for water cooling I might change my case now that I'm water cooling
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/715260-help-on-custom-loop/#findComment-9117863
