Air & Liquid CPU cooler
Hello everybody, please in need help choosing my cpu cooler. can anyone who know about this stuff help me.
best overall liquid cpu cooler
best overall air cpu cooler
that are compatible for both i7-4770k and i7-6700k
and which one is the better choice considering all factors (price performance ect.. etc
https://linustechtips.com/topic/715137-air-liquid-cpu-cooler/
For liquid cooling a commonly found aio cooler is the Corsair h100iv2.
http://www.corsair.com/en-us/hydro-series-h100i-v2-extreme-performance-liquid-cpu-cooler
A high quality air cooler is the Noctua NH-D15.
http://noctua.at/en/products/cpu-cooler-retail/nh-d15
For a cheaper alternative I a popular choice is the Cooler Master Hyper 212 Evo.
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
For the best overclock It is preferred an aio with at least a 240mm radiator or a really beefey heatsink. Aio's can generally have a larger price premium compared to an air cooler generally as they are more of a premium product.
https://linustechtips.com/topic/715137-air-liquid-cpu-cooler/#findComment-9116555
For the best overclock It is preferred an aio cooler or a really beefey heatsink.
hyperx would be better than evo.
https://linustechtips.com/topic/715137-air-liquid-cpu-cooler/#findComment-9116578
That is a fair point but it depends, I found on some research the fan on the hyperx is slightly better but for that price premium it is not worth it. They run quite similarly to each other. The only difference being the included fan.
http://www.tomshardware.com/answers/id-2461738/cooler-master-hyper-212-evo-hyper-212x.html
http://www.tomshardware.com/answers/id-2415588/difference-hyper-212-evo-hyper-212.html
There is so many options without a price range given its hard to choose a certain set of cpu coolers.
https://linustechtips.com/topic/715137-air-liquid-cpu-cooler/#findComment-9116588
would you guys prefer an Air or Liquid cooler ?
https://linustechtips.com/topic/715137-air-liquid-cpu-cooler/#findComment-9116594
1 minute ago, begadelavela said:
Liquid is just makeup it looks better but you can find good and even better air coolers for cheap like Nochtua.
If you will overclock I would go with liquid.
yes, if I am lucky enough that my chip will allow me to overclock ... I will
https://linustechtips.com/topic/715137-air-liquid-cpu-cooler/#findComment-9116598
To be honest it depends on numerous factors. Personally I would choose an aio if i did not have much space on the motherboard due to restrictions as high profile memory or the size of the case as the radiator can fit at fan mounts. If you have the space for a large air cooler then choose an air cooler.
The benefits of air coolers is that their is no need to worry about leaks or pumps failing and other maintenance issues as such.
The benefits of an aio is things such as aesthetics and they can fit in most cases.
https://linustechtips.com/topic/715137-air-liquid-cpu-cooler/#findComment-9116603
so can I overclock with a hyper 212x ?
https://linustechtips.com/topic/715137-air-liquid-cpu-cooler/#findComment-9116611
