http://m.imgur.com/EdBvh1o,E68qOJh,hD61sHW,cIQLZFH
The cpu cable by itself doesn't actually fit in the single motherboard header due to wrong shapes ,have tried multiple directions and knlynone side fits the onlynthing I have found that fits is thatbdual header that came with the PSU but only problem is in not sure if it is safe for me to use that if I am not using both cables so a little confused here as to why it won't fit
https://linustechtips.com/topic/715111-cpu-8-pin-help/
the standard cpu4pin shud fit in the cpu8pin , but only one side of it ,
but you have an 8pin there , but its split so it can be used on a board that only has a 4pin
what you have to do w/ that cable of yours is hold it together and insert it so the tab goes over the one side that has a latch for the tab to grip on
RyzenAir : AMD R5 3600 | AsRock AB350M Pro4 | 32gb Aegis DDR4 3000 | GTX 1070 FE | Fractal Design Node 804
RyzenITX : Ryzen 7 1700 | GA-AB350N-Gaming WIFI | 16gb DDR4 2666 | GTX 1060 | Cougar QBX
PSU Tier list
https://linustechtips.com/topic/715111-cpu-8-pin-help/#findComment-9116313
 It the two 4 pins that go together to form a 8 pin doesn't fit the shapes for them don't match what is in the cpu pin socket the only one that fits is the splitter that has two 8 pins and a 8 pin connection but I'm not sure if it is safe to use that splitter because i am thinking it has to plug into two 8 pin I have said this
https://linustechtips.com/topic/715111-cpu-8-pin-help/#findComment-9116429
what? how? its a normed part
PSU Tier list
https://linustechtips.com/topic/715111-cpu-8-pin-help/#findComment-9116433
If you look on the imgur link and look at the two left aide images (that is what it is for me) they don't don't match where as the two right side is the adapter but it has two 8 pin sides that go I to the motherboard
https://linustechtips.com/topic/715111-cpu-8-pin-help/#findComment-9116463
7 minutes ago, Dogsparky said:
On the bottom left hand corner there is a square shape while in the two four pins wheren itnwpuld go in it is a different shape
that ... is odd , very odd
but im looking at it , and it shud fit , how does the cable look from the other side , its it just yellow and black?
PSU Tier list
https://linustechtips.com/topic/715111-cpu-8-pin-help/#findComment-9116464
I can't see past the mesh on the cables,but it just simply won't fit the shapes are completely wrong unless ivuae the two cpu pin adapter
https://linustechtips.com/topic/715111-cpu-8-pin-help/#findComment-9116480
pics of that , also " ivuae " ?
PSU Tier list
https://linustechtips.com/topic/715111-cpu-8-pin-help/#findComment-9116483
4 minutes ago, Dogsparky said:
Sorry using my phone not ivuae I meant "I have"
if the adapter is just a cpu 4 pin to cpu 8 pin adapter it will work fine , not a fan of molex adapters
seems to be the only way to do it then
PSU Tier list
https://linustechtips.com/topic/715111-cpu-8-pin-help/#findComment-9116516
No the adapter is a single 8 pin to connect my cpu cable ,to two cpu 8 pin
https://linustechtips.com/topic/715111-cpu-8-pin-help/#findComment-9116521
oh , well if that works , go w/ that
PSU Tier list
https://linustechtips.com/topic/715111-cpu-8-pin-help/#findComment-9116524
Just now, Dogsparky said:
I'm not sure if that works and afraid it will cause problems and don't want to try it and seriously co aidering either getting a new motherboard or a different power supply
aslong as the polarity is correct it wont do any harm whatsoever
PSU Tier list
https://linustechtips.com/topic/715111-cpu-8-pin-help/#findComment-9116533
