Help with Skylake mobos
Go to solution Solved by smokefest,
4 minutes ago, Napalm360 said:
Hey so m in a pickle here,
i cant focus onto a single motherboard though i do have a selection and thought i would ask you guys for your opinion on the matter.
1. ASrock Fatal1ty Z170 Professional Gaming i7
2. ASUS maximus 8 hero
3.idk?? suggestion here please
my requirements is a board with A GREAT ocíng capability witha sleek BIOS and plenty of connectivity icluding
-Couple PCI_E X16 slots (yes ik that not all will run at full bandwith but it gives option to where i put cards)
-Thunderbolt/ USB 3.1 type a/c for my OP3T
on board oc tools like clear cmos, start etc.
Also a Black / Red theme would be nice thanks for help :D
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128836&cm_re=z170_gaming-_-13-128-836-_-Product
or
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128835&cm_re=z170_gaming-_-13-128-835-_-Product
are black n red asus ones
https://linustechtips.com/topic/714331-help-with-skylake-mobos/
or
https://linustechtips.com/topic/714331-help-with-skylake-mobos/#findComment-9107805
https://linustechtips.com/topic/714331-help-with-skylake-mobos/#findComment-9107813
2 minutes ago, Napalm360 said:
thanks acuually forgot to mention gigabte lol
many thanks
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813132641&cm_re=z170_gaming_asus-_-13-132-641-_-Product
I've build a 6700k in this board last week end. worked fine. oc'd well.
https://linustechtips.com/topic/714331-help-with-skylake-mobos/#findComment-9107823
how far:>
https://linustechtips.com/topic/714331-help-with-skylake-mobos/#findComment-9107828
any board will do that fine... any z170 i mean... jsut take one that fits ur $$$ range and ur needs...
i've oc my 6700k to 4.5 and it runs just fine, in cinebench cpu benchmark i get score of 990 with 4.5 ghz, and i get a score of 1030 @ 4.6 ghz,
For me, the voltage needed to reach a stable 4.6 was gettin my temperature over 80c so i decided to leave it at 4.5 ghz for temps under 75...
The performance between 4.5 and 4.6 is so small that i feel its not worth if your temps goes too high
https://linustechtips.com/topic/714331-help-with-skylake-mobos/#findComment-9107883
thanks just want to get 4.5ghz for thespeed really if that board is fine then im gong for it thanks, ;)
https://linustechtips.com/topic/714331-help-with-skylake-mobos/#findComment-9107941
7 minutes ago, Napalm360 said:
thanks, hows the build quality of the g1 gaming, anything to note
Nowadays, i believe the known trademarks like asus,msi,gigabyte,asrock etc.... have all proof in the past that they are solid builder..
You might wanna do some google search about the product you want to buy to see if theres any issues reported, but to be honest, i feel like they are all very reliable now.
i personnaly like asus and gigabyte
https://linustechtips.com/topic/714331-help-with-skylake-mobos/#findComment-9108094
Well. If you like to look at boards with punk ass vrms. Heres some i can recall off the top of my head.
Asrock OC Formula and the m varient
Asrock extreme 7+/Fatalit1y itx
Asus Hero/Gene/Formula/Extreme/Impact
Asus Deluxe/WS/Sabertooth
Gigabyte SOC Force/Gaming G1(the white one)
Msi Xpower
Evga FTW
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/714331-help-with-skylake-mobos/#findComment-9108482
