MAXIMUM SUPPORTED MEMORY SPEED
Solved by Lurick,
Just now, robbie_b said:Sort of... I'm asking if the chipset I'm using will limit my ram frequency to something lower than the ram i plan on buying this is 3000 MHz
Out of the box, yes. It will boot at 2133MHz until you overclock the RAM higher.
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
