hi guys can u help please
By
Kala
in Troubleshooting
in Troubleshooting
Solved by manikyath,
1 minute ago, Kala said:i havent set it up idk
set your bios to default, plug the SSD into sata port 1, plug the HDD into sata port 2. (the numbering should be either on the mobo or in the mobo manual)
i bet doing it the good old carey holzman way will make it work ![]()
toxic_worper ·
Posted in New Builds and Planning8 -
5
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
1
Vibora ·
Posted in New Builds and Planning5 -
5
3
