Hi guys, last time's post didn't really go well, so I decided to do more research to find the cheapest long-flight time drone, and I found this, the UDI U818A-HD (Link) and it's currently on a ~70% sale. Should I get this drone or something else? Please suggest a drone that will fly for a long time while cheap. Thanks!
https://linustechtips.com/topic/714187-help/
what's your version of cheap?
what's your version of long flight time?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/714187-help/#findComment-9106575
O yea forgot about that. My version of cheap is probs around 100$, because it's for my 'training' before I buy a good one
My version of long flight time is at least 8 mins, over 10 mins is better. That drone has around 10 min of fly time for each battery, so it has a total of 20 mins.
9 hours ago, OLS said:
That is a real cheapo drone for a higher price :) Don't expect much out of it
What do you mean? It is cheap for a higher price?
https://linustechtips.com/topic/714187-help/#findComment-9109502
Like it's a really cheap drone that they just put a higher price and a name on it. But if you want to just learn flying a quad I would check out for instance bangood.com, they got some pretty cheap drones just to get you up in the air and learning how to fly.
| Intel i5 4670k @ 4.3GHz | XFX RX 480 8 GB | Asus Z87i-Pro | 8.0 GB Kinston DDR3 | Samsung Evo 120GB SSD |
https://linustechtips.com/topic/714187-help/#findComment-9110629
Oh, sorry I live in Indonesia so I'm not too sure about the shipping costs and whatnot. Sadly, I don't have many choices. I also found the X5HW, which seems to be a bit better. Which of these two is better? Thanks!
https://linustechtips.com/topic/714187-help/#findComment-9111109
They should have free shipping, just put something in your basket on the website and check it out.
But do you want to get something big or small? You gonna practice before maybe going for something greater?
Would also suggest looking some of these videos:
https://www.youtube.com/user/TheRcSaylors/videos
They showcase quite alot of cheaper drones that are pretty decent :)
https://linustechtips.com/topic/714187-help/#findComment-9111151
2
Oh, that's cool. I would like something medium sized, like the ones I asked for. I have tried the parrot mini drone and it was absolutely f8ckin terrible and overpriced, so I decided to get something that is pretty inexpensive, but has good performance. Thanks! you're very helpful with this!
https://linustechtips.com/topic/714187-help/#findComment-9111206
