Mechanical Keyboard Help
Go to solution Solved by SeanAngelo,
2 minutes ago, Apollo Refugio said:
oh lol, the usb port fucked up. its working on my front panel I/O usb port
try another usb port at the back?
My mechanical keyboard isn't being recognized by windows. the error message says "windows does not recognize this USB device". Right now im using a membrane keyboard and its working. My mech keyboard (Rosewill RK9000v2) has a detachable cable, so is that a possible error? HELPPP I  CANT STAND MEMEBRANES
AMD Ryzen 7 7800X3D | Sapphire Pulse AMD Radeon RX 7900XT Triple Fan | G.Skill 32GB 2x D5 6000
https://linustechtips.com/topic/713708-mechanical-keyboard-help/
You could try another cable
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/713708-mechanical-keyboard-help/#findComment-9102354
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/713708-mechanical-keyboard-help/#findComment-9102371
well that was easy
https://linustechtips.com/topic/713708-mechanical-keyboard-help/#findComment-9102375
i plugged in back into the same USB port, i guess windows 10 was just being gay.
https://linustechtips.com/topic/713708-mechanical-keyboard-help/#findComment-9102380
