So i am in proces of building my first pc
Everything is connected and everything went fine untill now
I have everything connected but there is no post or beep
I removed the ram and tryed again to check the speaker
I got a contius beep (Ofc) so turn it off and started it again now no beep
I also tryed to remove GPU and boot like that but still no beeps
MB=Z170 gaming pro
I7 6700K
1x 8gb ddr4 hyper x RAM
GTX 1070 Armor OC
https://linustechtips.com/topic/713431-no-post-no-beep/
Remove everything except for the CPU and one stick of ram, try switching the ram around in case the ram modules or slots are not working, also make sure all the necessary power connectors are plugged in properly
Desktop: i7-6700K / Asus Z170 S / H100i V2 / LPX 2400Mhz 16GB / 960 EVO 250GB / 2x 860 EVO 500GB / RM750i  / NZXT H440 XB271H + Z22n Monitors
Laptop: Thinkpad T450s / i7-5600U / 12GB / 860 EVO 500GB
https://linustechtips.com/topic/713431-no-post-no-beep/#findComment-9099635
Okay, back to basics. Things you need for post.
Power supply
motherboard
CPU
1 stick of ram
(plug the monitor into the motherboard output for this test)
See if you get post, if not, try with a different stick of ram.
https://linustechtips.com/topic/713431-no-post-no-beep/#findComment-9099636
Power supply
motherboard
CPU
1 stick of ram
Tryed that still no beep
Removed the cpu to check connectors they seem all fine to me
https://linustechtips.com/topic/713431-no-post-no-beep/#findComment-9099673
Did alll pf that but i am getting DRAM light on Mobo
https://linustechtips.com/topic/713431-no-post-no-beep/#findComment-9099681
