5 minutes ago, Jackson D said:
I want to do a build with a Pentium G4400 but I have heard that it can be a major bottle neck any recommendations?
What kind of games you plan to play ?
Main PC:
CPU: Ryzen 5 3600  | GPU: RTX 2060 | PSU:  | Memory: Corsair Vengeance RGB 3200Mhz 16GB | OS Drive: Western Digital Black NVMe 250GB | Game Drive(s): Samsung 970 Evo 500GB | Motherboard:  | Case: Fractal Design Define R6 | Monitor(s):  | Keyboard:  | Mouse: Steelseries Sensei 310
NASUS (NAS)
CPU: Intel Xeon X3440 | Motherboard: Super Micro X8SIL | Memory: 16GB DDR3 1066Mhz ECC UDIMM | HBA: Dell Perc H200 (Flashed to IT Mode) | Drives: 3x 16TB Seagate Exos x16, 2x 6TB Seagate Enterprise, 1x 6TB WD RED
RENEKTON (NAS)
CPU: Intel Core i5 4570TE | Case: Fractal Design Define S | Memory: 16G DDR3 1333Mhz SODIMM | HBA: LSI 1068E (Flashed to IT Mode) | Storage: 4x 3TB Hitachi, 2x 3TB WD RED
https://linustechtips.com/topic/713408-gpu-for-cheapish-build/#findComment-9099389
1 minute ago, Jackson D said:
Arma 3, GTA V and Rust
Guess a Rx 470 would work fine enough since it's way better than the 1050 and blows the 460 to another dimension
Main PC:
NASUS (NAS)
RENEKTON (NAS)
https://linustechtips.com/topic/713408-gpu-for-cheapish-build/#findComment-9099399
Ok thank you I was thinking about either the rx 480 or maybe the 1050 but the 480 is a little pricey, so I guess it's the perfect balance.
https://linustechtips.com/topic/713408-gpu-for-cheapish-build/#findComment-9099429
That cpu would hold back the 480 a bit
Main PC:
NASUS (NAS)
RENEKTON (NAS)
https://linustechtips.com/topic/713408-gpu-for-cheapish-build/#findComment-9099433
my recommendation is to save money for an i3 at least and get a good gpu (such as 470 or 480) for avoid any "noticeable" bottleneck...
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/713408-gpu-for-cheapish-build/#findComment-9099457
25 minutes ago, Jackson D said:
Arma 3, GTA V and Rust. All I want is medium settings, 1080p and 60fps
A Pentium with strictly two cores is going to cause stuttering in those games because they're all significantly CPU-intensive.
Best bet would be to go for something like the i3 6100 if possible.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/713408-gpu-for-cheapish-build/#findComment-9099461
