Hey guys just wanted some more advice on my planned build.
I had planned a build involving an Intel Core i3-6100 and GTX 1050 Ti 4GB. But was able to increase my budget from 460 euro to 650.
I wanted to get advice on which components to upgrade first.
The original build -
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  (€114.00 @ Amazon Deutschland)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  (€53.99 @ Amazon Deutschland)
Memory: Crucial Ballistix Sport 8GB (1 x 8GB) DDR4-2400 Memory  (€44.09 @ Amazon Deutschland)
Storage: Western Digital AV-GP 750GB 3.5" 5400RPM Internal Hard Drive  (€39.80 @ Amazon Deutschland)
Video Card: Zotac GeForce GTX 1050 Ti 4GB Mini Video Card  (€156.70 @ Amazon Deutschland)
Power Supply: Seasonic SS-430GB Active PFC S12II-430 Bronze PC Netzteil (430 Watt, ATX 12V)  (€54.49 @ Amazon Deutschland)
Total: €463.07
https://linustechtips.com/topic/713174-build-advice/
1 minute ago, CFstorm said:
Your i3 is a great choice. I would use every dollar of your extra budget on your gpu. The gpu is really what makes the difference between and hero or zero PC.
I'm a beginner to this but would the cpu not bottleneck a higher end gpu?
https://linustechtips.com/topic/713174-build-advice/#findComment-9096802
1 minute ago, deXxterlab97 said:
No it won't. See if you can get a 470 or 480 or a 1060. Maybe but for lower end build will be fine
2 minutes ago, CFstorm said:
Nope, you could do a 1060 no problem without any bottlenecks, that's why your i3 is a great choice.
Cool, thanks for help.
https://linustechtips.com/topic/713174-build-advice/#findComment-9096829
https://linustechtips.com/topic/713174-build-advice/#findComment-9096859
