I need to but 2 microphones but I really have no knowledge in this space.
The first one is for my sister, she wants to record herself singing for some odd reason. Anything that fit this perpose and costs 150$ or less should be just fine.
The second one is for my self. The cheaper the better, I guess 50$ is just about my range for this. Just for normal use, nothing more. I do however want to sound clear without any white noise.
As for the first one, if any other equipment is needed please tell me as well.
Thanks
https://linustechtips.com/topic/712643-recommendation-for-2-mics/
A Blue Yeti for your sis should do just fine, no other equipment because it is USB I believe.  And for you I would recommend either the Blue Nessie or Blue Snowball, both are USB mics.  I have the Blue Nessie and it is perfect for general use, I assume video games, voice chat etc etc.
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
The blue yeti does seem to fit the purpose, It fit the budget, it doesn't require her to get extra equipment and it got some great reviews.
Looks like I'll get it.
Thank you for our time.
As for me the snowball looks kinda ugly but as long as it works I might get it as well.
