Either get a different card, EVGA 1070 Black Edition is $400 on Amazon I think or drop the speakers.
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
https://linustechtips.com/topic/712594-help/#findComment-9091156
Note that monitor only supports 75hz with freesync enabled. You don't have an AMD gpu so you are stuck with 60hz. Get a different monitor to lose about 20$ to get to 1500, maybe?
I5 4440//8gb Corsair Vengeance ddr3//Sapphire Radeon r9 380 4gb//ASUS h81m-plus//WD caviar blue 1tb//Cooler Master N200//Cooler Master G500
https://linustechtips.com/topic/712594-help/#findComment-9091304
So, what monitor should i get price aside.
https://pcpartpicker.com/list/MRvfVY
https://linustechtips.com/topic/712594-help/#findComment-9091376
Dunno, something like this?
https://pcpartpicker.com/product/mWV48d/benq-monitor-gl2460hm
https://linustechtips.com/topic/712594-help/#findComment-9091397
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.88 @ OutletPC)
Motherboard: ASRock Z170M Extreme4 Micro ATX LGA1151 Motherboard  ($110.98 @ Newegg)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory  ($69.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($93.88 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.78 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1070 8GB G1 Gaming Video Card  ($399.99 @ B&H)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($59.99 @ NCIX US)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.88 @ OutletPC)
Monitor: AOC G2260VWQ6 21.5" 1920x1080 75Hz Monitor  ($131.12 @ Jet)
Keyboard: Corsair Vengeance K65 Compact Mechanical Gaming Keyboard Wired Gaming Keyboard  ($59.99 @ Newegg)
Mouse: Logitech G302 Daedalus Prime Moba Wired Optical Mouse  ($33.27 @ Amazon)
Headphones: Logitech G430 7.1 Channel  Headset  ($37.99 @ Newegg)
Speakers: Logitech Z313 25W 2.1ch Speakers  ($39.99 @ Best Buy)
Total: $1426.72
Generated by PCPartPicker 2016-12-26 19:23 EST-0500
https://linustechtips.com/topic/712594-help/#findComment-9091640
Total: $1426.72
For 30 bucks more i think the look is worth it, but i still don't know about the monitor? what makes AOC's monitor better then the BenQ?
https://linustechtips.com/topic/712594-help/#findComment-9091683
what are you talking about when you say $30 more, and the moniter is good for its price but ifyou want a better one give me a budget and ill find 1
https://linustechtips.com/topic/712594-help/#findComment-9091709
https://linustechtips.com/topic/712594-help/#findComment-9091739
5 minutes ago, _kooky_ said:
What i am saying about the 30 dollars is by changing the motherboard you loss the nice red and black look, so i would much rather keep that seeing the price i will be paying and my max budget is 1500 dollars.
what color scheme are you fine with? like just red and black or is white and black ok
https://linustechtips.com/topic/712594-help/#findComment-9091754
Motherboard: Gigabyte GA-Z170MX-Gaming 5 Micro ATX LGA1151 Motherboard  ($124.99 @ NCIX US)
Monitor: Acer GN246HL 24.0" 1920x1080 144Hz Monitor  ($188.83 @ Jet)
Total: $1498.44
Generated by PCPartPicker 2016-12-26 19:45 EST-0500
https://linustechtips.com/topic/712594-help/#findComment-9091766
