Problems with gsync & Heat ?!?!?!
Solved by >( .____.),
21 minutes ago, APasz said:Then this is a visual glitch, nothing more. it will be fixed in due course. If you don't like the behaviour, turn it off of set a static colour in the monitors OSD.
Anyway, a lot of heat is generated which is concentrated center bottom of the screen. So unless you are getting artifacting or a non-responsive screen, it's fine and nothing to worry about.
If gsync is enabled, all communications with the monitor will be going through the gsync protocol, the option to exclude windowed applications is simply a compatibility option.
Set a static color in the monitors on screen display ?. You can't?
