2 minutes ago, Jaxy said:
CPU i7 6700k Not over clocking, and MOBO is gigabyte H170 Gaming 3. It is a OEM version, honestly bought the key off a website.... So I would assume it's a OEM key
You can just swap the mobo and cpu in, it should boot. If windows fails activation, type the key in again, still fails, call them up.
https://linustechtips.com/topic/711504-new-cpu-mobo-help/#findComment-9081788
It will probably fail.
This isn't too bad though, even if you are too lazy to activate it all it does is show "Activate Windows" in a light grey in the bottom right of your desktop
https://linustechtips.com/topic/711504-new-cpu-mobo-help/#findComment-9081802
Is it OEM or upgrades that are tied to the specific motherboard they are first activated on? Can't remember, but you can always buy a new key.
I spend too much on my PC. Then I spend even more on my Sim Rig. Damn, this stuff's expensive.
https://linustechtips.com/topic/711504-new-cpu-mobo-help/#findComment-9081841
