1 minute ago, Cookieontherun said:
I have selected the USB itself and tried to boot of that if that's what you mean if not please elaborate
Is it a Windows install USB from Microsoft or did you burn the ISO to the USB?
i like linux
Is they any way I could confirm if it has a windows ISO I have a laptop
yes plug it in and check it in the explorer If you could do a print screen of what is inside that folder and post it here than we know more.
i have checked the usb and it has
a disk image file labled en_windows_8.1_enterprise_with_update ect it is 3gb big aswell
and a text dcumet labled key which is 1 kb big
Really weird  But why don't you install windows 10 on it if you buy an oem key it's not that expensive and the installation tool has never let me down.
You have a lot of sites like these https://softwarelicense4u.com/nl/windows-10-professional-licentie-32-64bit-nederlands?gclid=Cj0KEQiA-f3CBRCbluKf4vu008kBEiQAl-iGq7xyuC9MXOSAmX16ovMI3nBAgGZrOiKgTdgCUTH3xkcaAtPy8P8HAQ where you can just buy them for 30 euro but I would look for a site from your own country.
But I cannot guarantee you won't run into the same problem if the hardware is to blame.
Actually don't buy a key until you've installed it on your pc using this program https://www.microsoft.com/nl-nl/software-download/windows10
