UPS
Go to solution Solved by steffeeh,
The point with a UPS is partly to prevent hardware damage as well as software corruption (including OS) due to blackouts and/or brownouts, but most importantly to be able to save things properly and then shut things down correctly (or simply just to be able to continue working on battery power until the power comes back) which can be crucial for certain workflows.
This also applies to households with an ancient electrical system where the electricity might not be the cleanest one (at least not if you're running on cheap power supplies).
UPS's are kinda expensive though, but they have their place in the tech world, so it's more about the need for it rather than wether it's worth it or not.
PS. There's no point in plugging in a laptop in a UPS because obviously the laptop already has a battery.
It depends.
For example, if you live in a place that never experiences power outages and your hardware is a shitty $300 laptop, then probably not.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
https://linustechtips.com/topic/711313-ups/#findComment-9079836
Asus X99-A w/ BIOS 3402 | Intel i7 5820k OC @4.4GHz 1.28V w/ Noctua NH-U14S | 16GB Corsair Vengeance DDR4 OC @2666MHz 12-14-14-28 | Asus Geforce GTX970 STRIX OC | EVGA 750 G2 750W | Samsung 850 Evo 1 TB | Windows 10 64-bit | Be-Quiet Silent Base 800 w/ Silent Wings | 2x Dell U2414H OC @72Hz w/ Display Port
Don't forget to invest in an Intel Tuning Plan if you're going to overvolt your K/X CPU
https://linustechtips.com/topic/711313-ups/#findComment-9079944
