Displays compatible with razer blade
I have a razer blade 14" and the screen is displaying the same images three times. I tried restoring the computer but it's still there so I guess the LCD is damaged. What screens will work with this laptop, and does anyone know how to repair this? (See below picture)
https://linustechtips.com/topic/71100-displays-compatible-with-razer-blade/
Corsair 350D - ASUS Maximus V Gene - Intel 3770K @ 4.6Ghz - Corsair H100i - G-skill Trident X 2666Mhz 4x4Gb - 2 x EVGA GTX 680 Classified 4Gb @ 1250Mhz - Corsair 860i - 2 x Samsung 840 Pro 240GB (Raid 0)
attatch a pic?
I'm not sure that this is a display problem I would say GPU-u. Actually it's definitely GPU so changing that display won't help...
"Play the course as you find it. Play the Ball as it lies. And if you can't do either, do what's fair."
No, unfortunately not even NVIDIA would be able to repair it, if a GPU goes bad it must be replaced.  Depending on whether the GPU is socketed, or soldered to the system board, you may have to replace the system board.  If that is the case it will be very expensive if you don't use your warranty to cover it.
