Hi, it's my first time building a PC and am having trouble determining what the best power supply is for this build.
Case: Phanteks Eclipse P400
Motherboard: Gigabyte H170M-D3H DDR4
CPU: Intel i5 - 6500
GPU: Zotac GTX1060 Mini 6GB
Ram: Crucial 2133MHz DDR4 (2 X 4GB)
Storage: Samsung 850 EVO 500GB
PSU: ???
Are there any bottlenecks in this build as well? Thanks!!
https://linustechtips.com/topic/710455-need-help-for-1st-pc-build/
PSU: ???
A Seasonic m12ii might be suitable for your build or you can pick one from here:
Tier 3 and above.
