Case Airflow recommendation
Go to solution Solved by iRileyx,
C would be the ideal one so that its a neutral airflow inside the case
A and D wouldn't be very good as having an intake right next to an exhaust on the same panel would cause turbulence and maybe cause a hot spot
Poll
6 members have voted
  1. 1. Which would be better? Please leave the reasoning below
    • A
    • B
      1
    • C
      5
    • D
I recently got 2 replacement fans for one of the stock fans that started making this grinding noise, I wanted to ask if anybody got a good recommendation to get the air moving in and out efficiently
I noticed my CPU temps are 2-3 degrees lower with the side panel open, which probably leads me to believe there is lot more warm air inside.
Fan placement is at the top
I got a little carried away making the image above, the choices are labeled with letters so I can add a poll, as more people would be happier to just press a single button to choose :) though I would love to read your reasoning for your choice.
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/710412-case-airflow-recommendation/
1 minute ago, Dutch-stoner said:
What do them arrows in your pic mean?!? Case arrows are in an horizontal plane, them choises are vertical. Please fix tis. (and maybe use colours)
He is talking about his fans on top. He wants to know which direction he two top fans should push.
Welcome to Maryland.
We have crabs.
I would go C, maaaayyyybe D. Ur that might just blow I got and blow cold air right out. Just make sure you have positive pressure.
We have crabs.
Could B work if he uses a reference GPU? It would be working as an exhauster.
Personal Desktop":
Luna, the temporary Desktop:
It's an Asus strix
Oh you are just asking in general, ignore this
ExSystems
Possibly, but the air being drawn in from the top could end up being pushed out the back by the flow from the front fans before getting chance to reach the gpu.
Not entirely sure, would have to get some incense sticks and test it out :P
1 minute ago, Sharif said:
It's a Asus strix
Then C is the way to go, so the hot air made by the GPU that is released inside the case is taken out.
Personal Desktop":
@Dutch-stoner @Cyndre1033 @RKRiley @Princess Cadence
Thank you everyone, I can finally put these fan into use. I have these laying around for awhile now, only because I can't make up my mind :)
ExSystems
