How much RAM do you have, what's your total budget, and where do you live?
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/710118-first-build/#findComment-9066194
2 minutes ago, newbie1234 said:
16 gb
So you have 16GB of RAM, a budget of 16GB, and you live in 16GB?
Dodge the question if you want, but I can't help you unless you tell me.
EDIT: I see you've added a PCPartPicker list. I'll see what I can do.
https://linustechtips.com/topic/710118-first-build/#findComment-9066208
http://uk.pcpartpicker.com/list/
better bang for buck imo
AMD FX 6300 @ 4.6 Ghz CRYORIG H7 Asus M5A97 PLUS | HyperX Fury 8 GB DDR3 | PNY CS1311 120gb SSD WD Blue 1TB 7200 RPM EVGA GeForce GTX 950 Superclocked NZXT Source 210 Black EVGA 500B Logitech G Pro HP K3500 Wireless Keyboard |
https://linustechtips.com/topic/710118-first-build/#findComment-9066222
On 12/21/2016 at 9:52 PM, newbie1234 said:
this is my first gaming pc build here is what i have so farhttps://uk.pcpartpicker.com/user/RT5xSHOCKz/saved/#view=2HgBmG  and wanted to know what else i can do to it. it has to be ddr3 as i alredy have the ram
From your older posts I saw you're going for a 4690k (£210), plus a decent mobo from asus (£150)
https://linustechtips.com/topic/710118-first-build/#findComment-9066231
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (£323.26 @ More Computers)
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler  (£29.69 @ Amazon UK)
Motherboard: Gigabyte GA-Z97P-D3 ATX LGA1150 Motherboard  (£63.98 @ Amazon UK)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-2400 Memory  (Purchased For £0.00)
Storage: Patriot Torch LE 960GB 2.5" Solid State Drive  (£189.99 @ Amazon UK)
Video Card: Gigabyte GeForce GTX 1070 8GB G1 Gaming Video Card  (£374.16 @ Aria PC)
Case: BitFenix Nova ATX Mid Tower Case  (£29.39 @ Aria PC)
Power Supply: be quiet! Pure Power 9 500W 80+ Silver Certified Semi-Modular ATX Power Supply  (£62.87 @ More Computers)
Total: £1073.34
Generated by PCPartPicker 2016-12-21 20:11 GMT+0000
https://linustechtips.com/topic/710118-first-build/#findComment-9066245
