Hello,
     I was wondering if anyone could tell me a good cooler to get for my build i have everything but the cooler. I wanted to go with a hyper 212 evo but my only concern is that it will cost to much for what I am using it for and the noise it will make. Any advice would be greatly appreciated.
My build: https://pcpartpicker.com/list/W3ZmNN
ps: the 970 is in there because I got it used from my cousin.
https://linustechtips.com/topic/710060-help-picking-a-cpu-cooler/
The Hyper 212 Evo is one of the cheapest air coolers on the market, if it is too noisy for you replace the fan with a Noctua NF-F12.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
Thank you for this I never knew you could replace the fan on your cooler
what is a good cpu cooler can be a cheap liquic or air 120mm height.
cpu i5 6500, it would be good if it is white.
Cooler Master Hyper 212 Evo if you really need it however I would just use the stock cooler.
زندگی از چراغ
6 hours ago, begadelavela said:
will it keep my mobo or gpu cool because it push air down and can I replace fan
It will provide bit of downdraft airflow over the motherboard and help move air around a bit which would only be useful if you're passively cooling your graphics card.
The fan is on clips and there isn't any included mounting equipment for standard case fans. Why replace the fan?
