Its fine, but don't spend so much on a gtx 1060 and get an ssd to pair with that hdd.
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9063955
What i'd get:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($324.99 @ Newegg)
CPU Cooler: Thermaltake Riing Silent 12 Red 53.0 CFM CPU Cooler  ($37.99 @ SuperBiiz)
Motherboard: ASRock Z170 Pro4 ATX LGA1151 Motherboard  ($99.99 @ SuperBiiz)
Memory: GeIL EVO POTENZA 16GB (2 x 8GB) DDR4-3000 Memory  ($84.99 @ Newegg)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($69.99 @ SuperBiiz)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($68.15 @ NCIX US)
Video Card: XFX Radeon R9 Fury X 4GB Video Card  ($319.99 @ Newegg)
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case  ($64.99 @ Newegg)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($88.58 @ OutletPC)
Case Fan: Corsair Air Series SP120 High Performance Edition (2-Pack) 62.7 CFM  120mm Fans  ($27.88 @ OutletPC)
Total: $1247.53
Generated by PCPartPicker 2016-12-21 04:33 EST-0500
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9063988
@Tahsin Alam What is your budget and in what currency? :)
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9063993
Just now, Tahsin Alam said:
Currency is Bangladeshi Taka
Budget 110000 taka
So I assume approximately $1400 USD? :)
My Daily Driver:
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9064003
My only suggestion is to add an ssd if possible. Also, WD black drives Aren't really necessary for many consumers, Blue is fine for most uses.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9064019
4 minutes ago, Tahsin Alam said:
Yeah.But the price of the parts is a bit more in our country though
I swapped the motherboard out with a red/black theme to suit your build's color. It also has red LEDs which will suit the Avexir Core's LEDs. I also managed to fit in a GTX 1070 and added in a 240GB SSD. :)
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($229.99 @ Newegg)
CPU Cooler: CRYORIG M9i 48.4 CFM CPU Cooler  ($19.99 @ Newegg Marketplace)
Motherboard: Gigabyte GA-Z170X-Ultra Gaming ATX LGA1151 Motherboard  ($148.47 @ B&H)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory  ($80.99 @ Newegg)
Storage: ADATA Premier SP550 240GB 2.5" Solid State Drive  ($68.99 @ NCIX US)
Storage: Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive  ($58.82 @ Amazon)
Video Card: Gigabyte GeForce GTX 1070 8GB G1 Gaming Video Card  ($399.99 @ B&H)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: Corsair CXM 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($81.20 @ Amazon)
Total: $1271.89
Generated by PCPartPicker 2016-12-21 04:46 EST-0500
My Daily Driver:
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9064021
1 minute ago, wONKEyeYEs said:
Hi Tahsin. Looks Good. I would definitely add an SSD for the boot drive. Even if your games are installed on the HDD things will run faster, except for loading times. And depending on what your playing, I would consider maybe going for the 1070. But that's just me. ;-)
Good Luck
Thanks for your suggestion. I would Go for a WD blue 1TB and a 250 gb ssd
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9064022
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9064027
Total: $1271.89
Thanks for your suggestion bruh.All the changes you have done i will go with it.But if i keep the corsair h100i cpu cooler.will it be a problem?
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9064030
Total: $1271.89
i5 bottlenecks 1070... its not worth if you can get an 1070, why do you get a i5? his previous build was pretty fine imo...
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9064037
Its ok if you go with the h100i, though there's not really a point in that unless you're going to be overclocking your CPU really hard. :)
My Daily Driver:
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9068942
No it doesn't. The i5-6600K will handle the GTX 1070 well at stock speeds. With overclocking, as OP is most likely to do, it will push both components further and yield an improvement in performance. :)
My Daily Driver:
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9068945
then, why when i see people who records gameplays with that gets around 90% cpu and 80% gpu? its because they are recording? what about playing at 144hz?
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9069661
Yes, recording eats up some resources. By the way, a GTX 1070 can push beyond 60 FPS easily on most games at 1080p. It is most suitable for use at 1440p where 60 FPS would be its sweet spot. If you want to play at 144 Hz with a GTX 1070, 1080p should be the best resolution for it. :)
My Daily Driver:
https://linustechtips.com/topic/709945-gaming-pc-buildneed-help/#findComment-9070032
