Help with a keyboard mouse combo.
Go to solution Solved by Verne,
CM Storm Recon would be a great match for the Quickfire. Corsair Raptor M40 is another good option.
More details, we need more details.
Specs of my PC:
CPU: AMD FX 8350  Motherboard: Gigabyte 990XA UD3  GPU: Gigabyte GTX 770 Windforce 2GB  HDD: WD Green 2TB SSD:  Corsair Force GT 120GB SSD RAM: Corsair 8GB(2X4) PSU: CoolerMaster G650M
If you wanna stick with CM storm, I have the sentinel advance II; it's pretty good.  Glows different colours so you can match it xD.  Other than that it's just a cool right handed mouse.  The mouse buttons are a little more firm and maybe less satisfying than some of the softer ones I've tried.  Not as comfortable as the razer death adder or Logitech g700, but still good. I got mine for 20$ at ncix a few months ago.
First Build:| Gigabyte 990FXa-UD3 | FX 8120 4.0Ghz | Coolermaster Seidon 240M | Asus Radeon HD 7870 | Kingston HyperX 3k 120GB SSD + WD Green 2TB HDD | Corsair RM750 | 8Gb Kingston HyperX 1866Mhz CL9| Fractal Define R4 White/Windowed |
For FPS there's nothing better but optical mice.
I'd suggest the G400s.
But it ultimately comes down to which kind of mouse you are looking for [shape-wise] ^^
Frost upon these cigarettes.... lipstick on the window pane...
 If you are looking for something wireless I have heard only good things about the Logitech G602. If you would prefer something wired then I have the Corsair M65 and thoroughly enjoy it and the "sniper" button on the side. Keep in mind I have no idea what your budget is and these mice will set you back a bit.
