I plan to get an S340 and paint the PCI-E brackets and SSD mounts blue because the s340 doesn't have much blue on it. I also have plans for RGB leds from cablemod.com because those are compatible with ASUS aura and the Motherboard I want has support for it (It's a Z170 Pro Gaming/Aura). I have a thread already in the cases section but I think I will get more ideas here. I want to put on some Vinyl Wrap for a racing stripe or something like moderator W-L suggested in the other thread. I don't really have a clue how I want the Vinyl wrap on it. Any ideas? I would really appreciate it.
"You think your Commodore 64 is really neato! What kind of chip you got in there a Dorito?" -Weird Al Yankovic, All about the pentiums
PC 1(Lenovo S400 laptop):
CPU: i3-3217u
SSD: 120gb Super Cache mSATA SSD
HDD: Random seagate 5400rpm 500gb HDD
RAM: 8GB Crucial DDR3-SODIMM
OS: Windows 10 education
PC 2(2014 Mac Mini):
CPU: i5-4260u
HDD: 5400rpm 500gb
RAM: 4gb DDR3 (soldered on :( )
OS: MacOS Sierra/Windows 10 pro via bootcamp
https://linustechtips.com/topic/709344-s340-modding-ideas/
Check out this guide on modding stuff. It's really helpful. I agree neither S340 nor H440 has enough blue on it and other case does not have the same superiority in quailty as NZXT. Though do check Apevia, Bitfenix and Sharkoon or Enermax. They might give you more blues.
https://linustechtips.com/topic/709344-s340-modding-ideas/#findComment-9057152
Thanks. I did bookmark that page so I can see it later. For now, I just want ideas. Definitely will be helpful later on though.
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
https://linustechtips.com/topic/709344-s340-modding-ideas/#findComment-9057159
Just now, huilun02 said:
If you really want to mod an S340, you can cut out the PSU shroud so it can be taken off from the front, and hollow out the front panel to turn it into a hinged door.
That would be awesome but I am just looking for aesthetic mods.
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
https://linustechtips.com/topic/709344-s340-modding-ideas/#findComment-9057209
Get the white S340 and give it a paintjob on the plain back panel
Maybe. I might do something like that on the black and blue one because that is the color scheme of my setup. I do love that idea though. Imagine the s340 black and blue model but the sides and front are blue too. That would look badass.
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
https://linustechtips.com/topic/709344-s340-modding-ideas/#findComment-9057269
I opened up tinkerCAD, loaded up an existing 3d model of the S340 and changed it up. I think this is going to look amazing. I will have to cut the vinyl wrap on the top so it doesn't block the vent and cut the vinyl for the side panel window but it looks great other than that.
https://tinkercad.com/things/dQivhBCBt7s
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
https://linustechtips.com/topic/709344-s340-modding-ideas/#findComment-9057501
Get some vinyl wrap and cover the top fan bracket/panel if you're not gonna use it (you shouldn't if you want positive pressure inside.)
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
https://linustechtips.com/topic/709344-s340-modding-ideas/#findComment-9058357
So covering it will help if I am not using it?
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
https://linustechtips.com/topic/709344-s340-modding-ideas/#findComment-9059068
Yeah. Less dust coming in.
https://linustechtips.com/topic/709344-s340-modding-ideas/#findComment-9059233
Thanks. I can easily cut a hole for the vent if i ever need too also. I would have never thought of that on my own.
CPU: i3-3217u
CPU: i5-4260u
HDD: 5400rpm 500gb
https://linustechtips.com/topic/709344-s340-modding-ideas/#findComment-9059356
