As i am speaking, i am on my recently 'fixed' computer and i am using google chrome. I am only able to launch Google chrome for some reason because Microsoft edge closes straight away and IE has an issue connecting to the internet. I do not understand this because i have an ethernet cable plugged in and i am connected to the internet which is how i am writing this but when i try to run skype, the windows store or steam i am getting a "Sorry, cannot connect to the internet" error status but i do not understand why this is appearing. I am clearly connected to the internet and using it. Please can someone help.
https://linustechtips.com/topic/708709-help-needed/
Why is this a problem? You should be using chrome anyways
AMD FX 6300 @ 4.6 Ghz CRYORIG H7 Asus M5A97 PLUS | HyperX Fury 8 GB DDR3 | PNY CS1311 120gb SSD WD Blue 1TB 7200 RPM EVGA GeForce GTX 950 Superclocked NZXT Source 210 Black EVGA 500B Logitech G Pro HP K3500 Wireless Keyboard |
https://linustechtips.com/topic/708709-help-needed/#findComment-9050552
It is a problem because i need to use skype but i cannot use the desktop app because none of them are connecting to the internet. Skype, Steam, The Windows Store and a broadcasting tool i use aren't connecting to the internet yet i can use google chrome fine.
https://linustechtips.com/topic/708709-help-needed/#findComment-9050570
download skype and steam, what broadcasting tool do you use
https://linustechtips.com/topic/708709-help-needed/#findComment-9051000
