Have a q6600 and a rx460 what would be the cheapst psu for it that would work
https://linustechtips.com/topic/708651-build-psu-for-pc/
In the US, I would get this https://pcpartpicker.com/product/nB3RsY/seasonic-power-supply-s12ii620bronze
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/708651-build-psu-for-pc/#findComment-9049828
Just now, YaqinHasan said:
I'd guess you'd overclock that Q6600. Honestly any decent 500 watt unit will work, maybe the S12 or M12 from seasonic?
Its a oem mobo cant oc
https://linustechtips.com/topic/708651-build-psu-for-pc/#findComment-9049847
Well that hardware will use less than 200W under overclocked load. An EVGA 500B would probably do fine for you.
https://linustechtips.com/topic/708651-build-psu-for-pc/#findComment-9050724
The 450B is $35, but for $50 you can't not get a S12II 620W
Computer Specs:
https://linustechtips.com/topic/708651-build-psu-for-pc/#findComment-9052483
