case with everything on the front?
Go to solution Solved by liquidmagma,
48 minutes ago, Sabbilon said:
Fractal design Core Series has a front I/O module that you could relocated to the back (minor mod) and then just use the back as your front.   It is on top as received so maybe that would be good enough for you?   The 5.25 drive dvd would still be on opposite side though.
well this means that you woud have to make a custom case, because there's not any case like that.
