Ok so I have this old 2tb HP external hard drive that transfers data using fire wire and is powered via ac, When I plug it into my computer, nothing shows up in my devices and drives, I tried checking the device manager and detects it but i can't access the storage. In devices and printers it says HP Personal Media Drive, but still cant access files, I troubleshoot the drive and it says "USB Mass Storage Device is an older USB device and might not work with USB 3.0, I check my motherboard manual, plug it into my USB 2.0 port and still says the same thing. I've tried uninstalling the drivers, restarting, and when I check it says they're fully updated but still can't figure out why I can't access the files. Heres the drive: https://www.amazon.com/HP-HD20000z-Personal-Media-Drive/dp/B003Y5AN8M
Ariana Grande's Leaked Nudes!!!111!11!
Ayyyyyy
Gaming Rig:     CPU:  i5-4690k  Cooler:  H80i  Mobo:  MSI z97 PC MATE  RAM:  16gb Fury White  Storage:  1TB WD + 120gb Fury SSD  GPU:  GTX 970  Case:  NZXT S340  PSU:  NEX 650W  Keyboard:  K65 RGB  Mouse:  Mionix Naos 7000  Headphones:  ATH-M50x  Monitor:  2x VN248h-P + 1x MG248q  Setup Photo:  (To come)
https://linustechtips.com/topic/707874-old-drive-not-working/
Does it click over and over? If not, the drive may still be alive so I'd open it up if so and try connecting from drive to mobo
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
https://linustechtips.com/topic/707874-old-drive-not-working/#findComment-9042248
What do you mean by clicking? If you mean by noises then theres a faint purr but definantly sounds like the disk is in tact
e: im gonna try and plug it into my macbook pro and see if it makes a difference.
Ayyyyyy
https://linustechtips.com/topic/707874-old-drive-not-working/#findComment-9042256
