1 minute ago, Cyndre1033 said:
Check to see if your front panel IO has all the headers plugged into motherboard.
And I'd also physically check the wiring while the system is off since it's not hot-swappable I don't think.
https://linustechtips.com/topic/707768-audio-promblems/#findComment-9040967
Did you check to see if the USB front IO header was on the right spot or was it just plugged in? It might be in the wrong spot. Maybe front IO header is broken, try plugging the headphones into the back to verify it isn't the headphone cable not working
Welcome to Maryland.
We have crabs.
https://linustechtips.com/topic/707768-audio-promblems/#findComment-9040990
