need help picking a mouse mat
Go to solution Solved by Albatross,
3 hours ago, katiekitsune said:
nah i had the glorious extended
Oh, well the Vipamz shouldn't warp unless they send ya a bad one, but in that case I still recommend the Glorious (small).
so ive gotten really tired of my razer manticor and all the issues ive had with sweat staining and dust and would like to get a new cloth mat (of reasonable size) ive come down to two options this glorious mat and the QCK limited. they are both around the same size as the manticor (the glorious is slightly bigger and machine washable while the qck is smaller)  and are perfect for the sensitivities i play at. ive owned glorious mats in the past and loved them they were just too big and one got warped from a hot bowl of soup (im also not a fan of the logo but it comes off if you work at it). which of the two is gonna be the best for my money?
wan
https://linustechtips.com/topic/707457-need-help-picking-a-mouse-mat/
I suggest this. Same price, a lot bigger.
https://www.amazon.com/dp/B0199GE7RC/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=24F9823LPZ8PG&coliid=I2I5IAHKFGL2TQ&psc=1
But of your two, I say the Glorious.
im not really looking for another extended since that was the one that got warped ( i move my keyboard back to eat but i like to have my mousepad not move)
wan
Oh, you had the Vipamz one before? My bad, I didn't see it your post. :$
