Which water cooling
Solved by slightlyjaded,
Just now, MrHelpMeOut said:Ok so you guys think that the dark rock pro 3 is the one Im looking for?
Sure, if you've got the ram clearance, it's a very pretty air cooler.
Check the ram height versus the product spec sheet before you buy.
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
kasdashd ·
3
6
Ishikudeska ·
Posted in New Builds and Planning2
play_circle_filled
Latest From ShortCircuit:
