So I'm considering on buying a CM Mastercase Pro 5, I'm wondering whether it's good for the following build or should I change to other cases.
https://pcpartpicker.com/list/BdvDQV
Check my Steam profile for games that I play. http://steamcommunity.com/id/childish_k1ll3r/
Planned Build PcPartPicker
https://linustechtips.com/topic/707043-coolermaster-mastercase-pro-5/
Personally i would get a cheaper case. But otherwise its good.
Other recommendations are however than you get a grey labeled cx550m https://pcpartpicker.com/product/3hkwrH/corsair-power-supply-cp9020102na since they are of higher quality.
And a cheaper motherboard, like the Asus Z170-A or equivalent.
And an IPS monitor for your video and photo editing work. I can imagine accurate colors are important.
1 minute ago, huilun02 said:
Why an expensive overclocking mobo when mounting only a Hyper 212?
Do you really need an i7?
If you need 1TB on an SSD there are much cheaper alternatives available
There are also cheaper 144Hz displays, some of which have Freesync.
You can ignore Freesync support if you insist on an Nvidia GPU. Or make use of it by getting an RX 480 instead.
The 1060 is a dead end card that can't SLI.
As for the case, there are many cheaper alternatives if there is nothing unique about the Mastercase that you want.
Even tempered glass cases like the S340 Elite and Crystal 460X
https://pcpartpicker.com/list/4pTZXH
Updated version
