I have these parts already
2x Titan X (Maxwell)
Asus X99-E WS/USB3.1
i7 6900K
I'm looking for a case, PSU, CPU Fan and 64gb Memory
It will be used for data processing and mass calculations,  this is the website http://www.cryoem.se/a-high-end-quad-gpu-workstation/
They recommend the Corsair Carbide Air 540 which looks like it fits E-ATX motherboards, I'm leaning towards corsair vengeance LPX 2133mhz and a Noctua NH-14S or NH-D14
They also recommend Corsair AX1500i or HX1200i
Can anyone recommend suitable alternatives? :S
https://linustechtips.com/topic/706181-new-build-parts/
There isn't an alternative to a solid psu.
For the CPU cooler you should do at least a dh-15. You could go with a Corsair h115i or h100i v2. The Lpx ram will be fine. The air 540 is likely the best case option purely because you have so much hardware in there.
3600X @ stocke | 5600XT TUF OC @ 1850 | 2x16 + 2x8 RAM 3200 HD | 1tb Samsung 970 EVO Plus | Lian Li 205M | TT Toughpower Grand RGB 850 | throwaway b450 asus mobo | BQ cooler
https://linustechtips.com/topic/706181-new-build-parts/#findComment-9023028
