i am currently working on building a PC inside the casing of a PlayStation 2 and i don't exactly know how to power it, i cant fit a power supply in it because i want it to look just like a PS2 and i dont want to have to have a regular ATX/SFX PSU hanging out of the back. it has a core 2 quad Q9550 4GB of ddr2 800 and a gtx 550 ti (all salvaged form a previous build) so I would very much appreciate any suggestions on how to power it, thanks.
https://linustechtips.com/topic/706093-ps2-case-build/
pico psu.
https://linustechtips.com/topic/706093-ps2-case-build/#findComment-9021017
I am finishing up a build in a PS2 also, haven't made a log or anything yet, but if you are careful with power you have some options.  I'm using a g3258 for the processor and a 750ti, a 150W Pico is more than enough even with overclocks.  The biggest problem I'm having is cooling in the tiny case.  Looking forward to see how you cool the little devil.
https://linustechtips.com/topic/706093-ps2-case-build/#findComment-9021072
Took me a while to find it but here is the other power supply I was thinking you might want: http://www.hd-plex.com/HDPLEX-250W-Hi-Fi-DC-ATX-Power-Supply-16V-24V-Wide-Range-Voltage-Input.html
250 watts of tiny goodness, not nearly as small as a pico but you can probably squeeze it in if you have a low profile gpu.
https://linustechtips.com/topic/706093-ps2-case-build/#findComment-9022489
  • 2 weeks later...
wow thanks and im asuming I would buy a 24 6 and 4 pin or do those come with it
https://linustechtips.com/topic/706093-ps2-case-build/#findComment-9067652
Let me know how it turns out. I think this is a great idea. I didn't even know that the PS2 case would even be big enough. Good luck. Hope it works out for you.
"You think your Commodore 64 is really neato! What kind of chip you got in there a Dorito?" -Weird Al Yankovic, All about the pentiums
PC 1(Lenovo S400 laptop):
CPU: i3-3217u
SSD: 120gb Super Cache mSATA SSD
HDD: Random seagate 5400rpm 500gb HDD
RAM: 8GB Crucial DDR3-SODIMM
OS: Windows 10 education
PC 2(2014 Mac Mini):
CPU: i5-4260u
HDD: 5400rpm 500gb
RAM: 4gb DDR3 (soldered on :( )
OS: MacOS Sierra/Windows 10 pro via bootcamp
https://linustechtips.com/topic/706093-ps2-case-build/#findComment-9068398
Honestly I'm not sure, I haven't used that power supply personally but I was contemplating using it before I went with a 150w Pico.  I've seen other builds with it, probably the most well known is the NES build that went around a good while ago.
https://linustechtips.com/topic/706093-ps2-case-build/#findComment-9070537
