1 minute ago, nerodas463 said:
I know that!
I wanted to know what volts should I choose.
The choices are like :-
.526
0.955
and it goes on!
What should i choose??
It should let you type in your own number.
Like 1.125 or 1.25 or whatever you want.
Only increase voltage if you blue screen when you up the multiplier
Everyone should own a vive.
4 minutes ago, nerodas463 said:
I know that!
.526
0.955
and it goes on!
You would start with just a small increase then stress test if unsuccesful increase more until stable or max temp exceeded
No it doesn't.
A pop up menu comes up displaying the numbers and i have to choose from the options.
Just now, Teknis said:
Well amd have their black editions for a reason
Ive never had an issue over clocking a FX chip with no "special" series or name.
2 minutes ago, nerodas463 said:
No i didn't touch anything!
And buddy I just looked into your Mobo and I would not OC with it
The Mobo can get too hot and break. The VRM on it s bad. The board was not made to OC.
But It has this OC genie thing only for OVERCLOCKING!!!
Yeah that's just part of the BIOS. Any board will have that.
And the genie will OC it for you if you turn it on but it won't be much.
But if the Mobo is the same one I found online don't OC with it
Not even a little ??
Well I suppose if it was tiny sure.
The issue is your Mobo doesn't have heatakins on the VRM so it won't dissipate heat fast enough if you OC so then you'll need to buy a whole new Mobo. Not a fun thing to do
