I don't know what happen but when i wake up in ther morning and turn on my computer i saw code 10 on dr debug i quickly searched what the code was about and it was memory, after a couple of tries and desactivate all the cables i turn on the computer with a screwdriver and it the computer turned on and the computer was normal it wasn't slowing or anything, i could listen to músic, vídeos or even play games without any problem, first i thought it was a cable issue causing it maybe a broken cable and the energy was leaking or something. But after i installed a new SSD and tried to turn on the computer in the smart button on the motherboard something very strange happened, dr debug kept cycling with multiple codes if not all the codes, but he stoped for 1-2 seconds in some codes that were 79,70,78,68,A9,b3 and 39, i started panicking and did everything i could to solve it. I Took all of the cables from the motherboard only leaving the CPU Fan, and PSU, still nothing, tried to clean up the board and the CPU still the same. Then i tried to test the memory ram in each slot one by one and and even the 2 and switched them both still nothing. Tried to reset CMOS battery, and reseting CMOS by jumper and by the Smart button still nothing, i thought of trying to reflashing my bios to older version but since the POST even doesn't come i didnt' do that (the screen is all black), tried to check it any transistor was broken on the CPU and there was none, reseated the cooler and still nothing. I removed the motherboard out of the box and the problem persisted. I removed all the cables and even removed the HDD and GPU and the problem of Dr. debug was still there. I also tried to replace the CMOS batery with a new one and nothing the problem was still there. The strange thing is that if i removed the 2 Memory ram slots of the motherboard, Dr debug appears the code 19 and doesn't gets out of there, and if i replace the memory ram sometimes appears the error 10, and even the dr debug led doesn't even turn on i have either to restart the pc or shutdown and turn on so that dr debug turns on. Please can someone help me with this i don't know if there is a problem with my CPU,Ram or Motherboard or even PSU. The Specs of my PC are: FX 8350 4.0@ Black Box Edition GTX 760 192-bit edition Gskill Ripjaws X CL7 2x4gb 1600mhz XFX 650W XXX Pro Edition Semi Modular Asrock 970 Extreme4 , Bios P2.80 Coolermaster Hyper 412S Seagate Barracuda 500GB SATA3 6gbps 16mb cache Kingston HyperX Fury 120GB MLC
Read more: http://forumstest.tweaktown.com/asrock/62976-dr-debug-crazy-codes.html#post504974
MOBO - ASUS EX -320M GamingMemory - Gskill Aegis 2x 8gb 2133mhz - GPU - Asus Phoenix GTX 1660 - CPU - AMD Ryzen  5 2600 3.9Ghz 65W - Case - Eurotech Slayer RX6 Elite Main SSD M.2 NVME - Blueray 120GB - SSD - Hyper X Fury MLC 120GB   - PSU - Seasonic M12ll 620W 80+ Bronze Full Modular  -
https://linustechtips.com/topic/705695-drdebug-crazy-codes/
Who is doctor debug?  You mean the post code display?
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/705695-drdebug-crazy-codes/#findComment-9016082
It's what ASRock calls it.  Most of the times, a doctor can fix a problem.  Not just tell you about it so they might want to rethink that name.  xD
https://linustechtips.com/topic/705695-drdebug-crazy-codes/#findComment-9016128
OK. I never knew that.
Is there a bios update for your motherboard?  Try that first. You could also ask asrock support.  The y are normally helpful.
Rig Specs:
https://linustechtips.com/topic/705695-drdebug-crazy-codes/#findComment-9016363
The motherboard comes with the BIOS P2.30 i updated to version P2.80 although i only remember to update to version 2.60 but okay. i updated it because i thought i had FPS drops and i thought it was because my CPU didn't was fully compatible with my motherboard so i update it. I wanted to reflash to version P2.30 but the computer doesn't even POST.
https://linustechtips.com/topic/705695-drdebug-crazy-codes/#findComment-9016483
  • 6 months later...
