Im not happy with the Phantek RGB LED strip. Mostly I don't like the silicone style, i broke it in half by bending it too far. I want a white LED with a sata or molex power connector. Is there anything better or cheaper than the NZXT braided LED strip? Its $30NZD which is a box and a half of beer or a box of really nice beer; I would like to spend no more than one box of cheap beer.
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/705603-white-led/
I personally like the darkside LED strips, although I'm not sure where to get them in NZ, I get them from a Canadian store. From the latest LTT video (floatplane club), I personally liked the look of CoolerMaster's solution, but haven't used it myself or seen extensive coverage.
Other than that cablemod and bitfenix both make popular solutions.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/705603-white-led/#findComment-9015147
