Logitech G930 vs Corsair Void Wireless
Looking for a WIRELESS headset to be used when i am gaming. I am finding a cheap wireless headset and I have decided on these two headsets. I know the G930 has some connectivity problems but there are some fixes online that might work so I have no idea if I want to risk it or just go for the Corsair Void Wireless?
https://linustechtips.com/topic/705221-logitech-g930-vs-corsair-void-wireless/
I have a G930 and those connectivity issues are either people being picky or they have faulty units.
Just so you know it operates on the 2.4Ghz band and uses channel 11.  I love mine, I give it a 9/10
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
Will it be affected if I have a router in my room and my phone and laptop connected to it?
Not if you turn your router over to channel 1 or 6... or you can be "that guy" and put it on 3-4...  hahaha
Not really sure about the channels of router so... How can I check the channel of my router?
Depends on the router.
