Fallout 4 problem, GPU or Game???
Go to solution Solved by Edgar R. Zakarian,
On 11/12/2016 at 1:30 PM, Constant Failure said:
problem was ENBDEV i had downloaded. due to older card maybe.
No.
I just reinstalled the game, that worked.
It seems that some of the texture files were corrupted during patching.
Wow.
Simple reinstall fixed everything :D
Thank you for your help!!
correction!!!
Fallout 4 is all dark! :/
No idea why.
I have the latest patch, 1.87, but it's all messed up!
Running latest crimson drivers (Beta 16.2.1) on the system in the signature.
I've played fallout at version 1.4 previously, and that worked fine.
Latest working drivers for patches prior Fallout 4, version 1.4 were 15.11 beta drivers. (Worked GREAT).
Then fallout 4 updated to 1.4 and above, and you needed the latest Crimson beta drivers 16.2.1 (which I'm using now)
Now Fallout 4 is on version 1.87, which looks like this on the latest Crimson drivers, from AMD's site :(:
Shooting adds lightning
INDOOR
I HAVE tried disabling ALL mods (Uninstalling them all). It's still the same with the full vanilla game :(
HEEEELP!!!!
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
https://linustechtips.com/topic/705209-fallout-4-problem-gpu-or-game/
I would say its the beta drivers.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
okay hmm...
It's weird, cause if you shoot nearby, there is lighting.
It's like a big shadow is covering everything.
1 minute ago, Edgar R. Zakarian said:
okay hmm...
Have you overclocked your GPU? Because seems like you have a bit of artifacting or unloaded resources on your screenshot. Is your GPU the same as your signature? But you're not the only one complaining about the new drivers. So that might be the issue.
CPU: i5 6600k @4.5GHz | GPU Zotac Amp! 1070 | RAM: Corsair vengeance 16gb | Storage: Corsair Force LE 240gb +480gb | Case: Corsair Carbide Clear C400 | PSU: Corsair RM650x | Cooler: H110i GTX
NO overclock, other than BIOS 1, which is factory OC to 880MHz, just like the stock settings for 6970, as this in principle is.
ALL other games are running fine.
hmm is there anywhere I can download unofficial drivers, that might have fixed this?
 Some russian might've done something? xD
You're probably better off just getting the old drivers you know that worked from AMDs site.
Except that they don't :/
Latest working drivers for patches prior 1.4 were 15.11 beta drivers. (Worked GREAT).
try the previous crimson driver (non-beta), I doubt the latest version of fallout 4 is so new it requires the driver from a few days ago
hello!
is it me you're looking for?
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
Cooler: Dark Rock Pro 3
RAM: 32GB DDR4
GPU: GTX 1080
Storage: 1TB 850 Evo, 1TB HDD, bunch of external hard drives
PSU: EVGA G2 750w
Peripherals: Logitech G502, Ducky One 711
Audio: Xonar U7, O2 amplifier (RIP), HD6XX
Monitors: 4k 24" Dell monitor, 1080p 24" Asus monitor
Laptop:
-Overkill Dell XPS
Fully maxed out early 2017 Dell XPS 15, GTX 1050 4GB, 7700HQ, 1TB nvme SSD, 32GB RAM, 4k display. 97Whr battery :x
Dell was having a $600 off sale for the fully specced out model, so I decided to get it :P
-Crapbook
Fully specced out early 2013 Macbook "pro" with gt 650m and constant 105c temperature on the CPU (GPU is 80-90C) when doing anything intensive...
A 2013 laptop with a regular sized battery still has better battery life than a 2017 laptop with a massive battery! I think this is a testament to apple's ability at making laptops, or maybe how little CPU technology has improved even 4+ years later (at least, until the recent introduction of 15W 4 core CPUs). Anyway, I'm never going to get a 35W CPU laptop again unless battery technology becomes ~5x better than as it is in 2018.
Apple knows how to make proper consumer-grade laptops (they don't know how to make pro laptops though). I guess this mostly software power efficiency related, but getting a mac makes perfect sense if you want a portable/powerful laptop that can do anything you want it to with great battery life.
There IS no non-beta crimson driver xD
The latest driver, prior to the Crimson drivers, is 15.7 - Non crimson.
And As I recall, it doesn't work with Fallout 4, patch 1.4 and above.
https://support.amd.com/en-us/download/apu/previous?os=Windows 10 - 64
any of those work for you?
No.
Wow.
correction!!!
