Hey guys! I hope you can help.
So I was cleaning my PC recently, and I noticed that there dust particles that are too big to pass through the filtered fan intake that is on front of my case, not to mention, that I have a 360 mm rad in front, that should act as a filter too. (somewhat) So I did a bit of research about it, found a vid from an unamed youtuber (name starts with a "J") Which is about airflow in your case. And that negative air pressure is the culprit, since it forces air in to unfiltered openings in your case.
So here is my fan lay out.
3x - 120 mm SP fans front
2x - 140 mm stock case fan top
1x -140 mm stock case fan rear
2x - 70 mm AF fans rear
Right away, you can see the ration of the fans will give out a negative pressure. I am not looking at adding fans for intakes. What type should I go for? SP or AF? Not that 3 of them will be mounted at the rad, for a push and pull set up.
Thanks!
https://linustechtips.com/topic/704894-airflow-vs-static-pressure/
Thanks!
You know yoo get a balanced airflow you can just flip some of the fans over(also you have to tell us which are intakes and which are exhausts)Also if it's stuck in the dust filter just clean the dust filter
Edited by Himommies
My life
It's hard to tell if there is negative air pressure if you don't tell us what fans are exhaust/intake.
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
Sorry,
3x - 120 mm SP fans front - Intake
2x - 140 mm stock case fan top - Exhaust
1x -140 mm stock case fan rear - Exhaust
2x - 70 mm AF fans rear - Exhaust
I cant flip the other fans since they are mounted on non filtered openings. I only have the front one to work with.
Just now, Object.426 said:
Sorry,
What case do you have I wanna use MS paint to draw a diagram
My life
Just now, Pheelo said:
Buy filters or make them yourself, and then flip the fans. Or simply remove some of your fans.
C'mon man! Don't wanna remove fans, I like them fans. Just wanted to know which fan type to use, Airflow or Static Pressure.
Static preassure seems to perform better 9/10 times, but it comes with a price: noise.
Have you tried actually unplugging some of them and monitoring the temperature levels? Youd be surprised how few is needed to maintain decent temperatures.
Blue for exhaust red for intake
Also where did you put those 70mm fans seems to me theres no room for them
There is a spot for those 70 mm fans, an I have it mounted beside the expansion slots. I could actually use an 80 mm, but I will have no space to remove the graphics card.
I don't think thats meant to be used as a fan spot
My life
I don't mind the noise. 1 vote for SP then.
6 hours ago, Object.426 said:
Sorry,
All fans have some degree of static pressure and airflow. Stating a fan is airflow or static pressure ultimately means very little.
What are your specs? What fans do you have?
