Realtime audio editing
Go to solution Solved by Moist_Sock,
8 minutes ago, VictorianReaper said:
for one thing i want to avoid accidentally making the effects
You can have multi-key bindings to prevent exactly that
second i want to know exactly what effect im adding
Your memory is generally pretty good at that after a while. You can toggle on listen to mic and hear exactly what is happening if you're worried about leaving something on or not.
10 minutes ago, VictorianReaper said:
third i want to make it as simple and as efficient as possible
Buying an entirely different unit/device does not sound simple and efficient to me.
11 minutes ago, VictorianReaper said:
i have a razer tartarus chroma is that what you mean my macro board things?
I have no idea how that functions, but If it essentially gives you a small re-bindable keyboard then yes, that Is what I was talking about. It depends exactly on the software you use though.
so im looking for hardware or software that i can use to manipulate audio from my mic, for example : pitch change, voice profiles like (a robot profile) in real time for live streaming or calls ii prefer if the program would be free
Dendrotoxin
CPU: i5 6600k @ 4Ghz | GPU: Zotac AMP! 1070 @ 2GHz | RAM Crucial Balistix 2x4GB | PSU EVGA G2 750w | Cooler: NZXT Kraken x61 | Case Phanteks Eclipse P400s | Motherboard Gigabyte G1 Gaming Z170 | Storage: Toshiba 3TB HDD and MyDigitalSSD M.2 256GB
Perripherals
Keyboard(s) Razer Ornata Chroma, Razer Tartarus Chroma | Mouse: Logitech G502 Spectrum | Headphone: Audio Technica M40x | Monitor HP 22CWA
https://linustechtips.com/topic/703882-realtime-audio-editing/
I believe you need a USB audio interface device for that.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/703882-realtime-audio-editing/#findComment-8996853
21 minutes ago, Pesukarhu said:
i understand i said software but hardware was my main preference, im sorry i should have stated that
Dendrotoxin
Perripherals
https://linustechtips.com/topic/703882-realtime-audio-editing/#findComment-8996975
im going to get a behringer uphoria um2 would that work?
Dendrotoxin
Perripherals
https://linustechtips.com/topic/703882-realtime-audio-editing/#findComment-8996980
Just now, Moist_Sock said:
An audio interface won't help with adding effects to your mic.
what would
Dendrotoxin
Perripherals
https://linustechtips.com/topic/703882-realtime-audio-editing/#findComment-8997165
Any voice changing program.
is there a way i could do that with a press of a button that is not on my keyboard
Dendrotoxin
Perripherals
https://linustechtips.com/topic/703882-realtime-audio-editing/#findComment-8997187
Get a second keyboard? [or one of those macro board things]
Why can't you just bind it to your KB??
Don't tread on me. I squish, and white liquid comes out. It's icky, trust me.
https://linustechtips.com/topic/703882-realtime-audio-editing/#findComment-8997190
for one thing i want to avoid accidentally making the effects. second i want to know exactly what effect im adding third i want to make it as simple and as efficient as possible i have a razer tartarus chroma is that what you mean my macro board things? if thats what you mean ill probably end up going with that option
Dendrotoxin
Perripherals
https://linustechtips.com/topic/703882-realtime-audio-editing/#findComment-8997214
https://linustechtips.com/topic/703882-realtime-audio-editing/#findComment-8997264
i appreciate your in-depth help and patience
Dendrotoxin
Perripherals
https://linustechtips.com/topic/703882-realtime-audio-editing/#findComment-8997269
