Hi guys.
I have a problem with a server running Windows Server 2012. When i set user needs to change password when he logs in a following message pops on client PC:
You must change your password before logging on the first time. For assistance, contact your system administrator or technical support.
If I recall correctly it used to pop change password screen. I found hotfix on M$ support website. However it's for Win Server 2008R2. ( https://support.microsoft.com/en-us/kb/2648402 )
Anyone had same issue?
PS: Sorry for bad english, I am from Poland.
https://linustechtips.com/topic/703837-rdp-connection-issue/
I tried it and there's a problem when I get to change password screen. After I input new password there's "Access denied" message. Do I need to assign user to another group? User now is in "Users" and "Remote desktop users".
Also there's recommendation client should use it only to change password. If I set password policy to last for like 30 days or so I will have to change it back and forth very often. There's like 15 users connecting to this server via remote desktop. That will be really painful to change it for everyone every 30 days just to let them change password. There's no other way? Preferably server side configuration.
https://linustechtips.com/topic/703837-rdp-connection-issue/#findComment-8996473
Do you need to have the users change their password every so often? What is the server used for?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/703837-rdp-connection-issue/#findComment-9001883
Server holds ERP app and users in other location connects to it. I don't need them to change password that often, my boss told me to make it happen, and I am sitting right here pulling my hairs out and trying to make it work. There's no option to just talk to me he is really stubborn person about data security after his data was stolen. I tried proposing other options like files encryption, but as I said he is really stubborn.
https://linustechtips.com/topic/703837-rdp-connection-issue/#findComment-9002019
There is a way to disable the "user must change password every so often" thing. I think it's a simple registry edit, but I can't remember. I did it on my server, because I share it with other, less tech inclined people.
Main System: Phobos
https://linustechtips.com/topic/703837-rdp-connection-issue/#findComment-9002091
Well I know how to change password policies so user won't have to change password every 30 days or so. I don't know how to let them change it. Whatever i do there always this thing.
Or if i put " enablecredsspsupport:i:0 " this little thingy in .rdp file after putting new password to change there's "Access denied" message.
BTW I just discovered that I can change password normally using Win 7 machine. However clients connecting to this server are using Win 8.1 and Win 10 machines.
https://linustechtips.com/topic/703837-rdp-connection-issue/#findComment-9002183
Have you tried logging into the user accounts locally on the server? This fixed the issue for me.
Main System: Phobos
https://linustechtips.com/topic/703837-rdp-connection-issue/#findComment-9002197
That works, but doesn't solve issue for me. I'll have clients travelling +200km just to change passwords. I need something to work like on the picture attached. It used to work like this in Win 7. When I log on user that needs to change password with Win 7 machine I have this exact screen that allows me to change password and start working right away.
https://linustechtips.com/topic/703837-rdp-connection-issue/#findComment-9002219
Just set up the accounts and then have the client tell you what the password should be. Set that as the password, and done. Then the client can log in with the account having been already set up.
Main System: Phobos
https://linustechtips.com/topic/703837-rdp-connection-issue/#findComment-9002276
