Hi i bought my graphics card (GTX 750Ti FTW Edition) from a store in my country (barbados) and i've tried overclocking it but i only get up to 1234 mHz (GPU Clock) ,1588Mhz (Memory Clock) and 1313 mHz (Boost Clock).When i try to use DSR to try to upscale my game to 4k or 1080p or any resolution other than 1360x768 my screen looks very distorted and stretched sometimes tiny text and as if it were zoomed out.And whenever i try to overclock my monitor/tv it only goes up 1 herts on the refresh rate no higher. When i play a game called war thunder i also get alot of flickering  even with a slight overclock..i've updated drivers countless times and nothing seems to work please help
https://linustechtips.com/topic/702683-help-me-please/
Well, it seems as if your GPU cant go further than 1234Mhz. Totally normal.
what is your native screen resolution? always do everything at the native resolution, and it wont look stretched.
maybe your monitor doesn't support overclocking or doesn't overclock well?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/702683-help-me-please/#findComment-8981793
If your monitor isn't DisplayPort connected I wouldn't try to overclock it.
As for DSR, you can adjust text on Windows but some games will just not work well with it. It's just not well implemented.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/702683-help-me-please/#findComment-8981833
