hard drive help?
Go to solution Solved by RadiatingLight,
1 minute ago, pi1992 said:
Im most likely sure that it has an os on it, so i chose my ssd to boot from but then windows starts to do a repair for some reason and won't boot.
what happens if you let windows finish repairing?
i currently have a 250gb ssd and a 1tb hard drive installed, the ssd being my boot drive. the 1tb hdd is full so im trying to install an old 500gb hdd that i had laying around. most people say to plug it in and boot from the normal drive then go into the control panel and format the drive from there, but when i plug in the third drive, windows doesn't want to load. any help?
https://linustechtips.com/topic/702273-hard-drive-help/
Make sure that the new drive doesn't have an OS on it. if it does, make sure to boot from your SSD
It can be tricky, (disclaimer here: do this at your own risk!!) But maybe wait until the OS has booted, and then plug in the SATA data connector into the motherboard/HDD?
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/702273-hard-drive-help/#findComment-8976923
https://linustechtips.com/topic/702273-hard-drive-help/#findComment-8976934
Laptop:
https://linustechtips.com/topic/702273-hard-drive-help/#findComment-8976942
20 minutes ago, abhansh21 said:
let the window finish repairing
or if your motherboard supports got swap then just plug in your boot drive and then plug all the other drives when you have booted up
i tried the hot swap and now when i go to look at the partitions in windows it just says connecting to virtual disk service
https://linustechtips.com/topic/702273-hard-drive-help/#findComment-8977067
try formatting that 500gb hard drive on some other pc or make a bootable usb of any os and format that 500 gb hard drive and then try the hot swap method
https://linustechtips.com/topic/702273-hard-drive-help/#findComment-8985700
