Need Help Cant figure Water cooling out
Solved by atomicus,
Have you used the EKWB Configurator? That should break things down for you in an easy to understand fashion. Basically though, you need x2 fittings for each component, as each has an in and out. So for CPU block, single rad and pump/res (if a combined unit), you would need 6 fittings. The size of the fittings depends on the size of your tubing. The configurator does this for you though. For soft tubing you probably could get away without any 45/90 degree fittings, but it depends. However, you would also be advised to fit a drain port, which will require a ball valve and some other fittings in order to locate this somewhere in your loop (preferably at the lowest point to make draining easier).
