I want to see my GPU stood up because why not?
Obviously I'll need a long riser card so it clear the expansion slots but then how (What would I use to cut through the reservoir slot) and how would I secure my card in place?
What good GPU riser cards are there?
How would I go about doing this mod
How much would it cost?
https://linustechtips.com/topic/701023-phanteks-enthoo-pro-m-case-mod/
I have the same case. I was thinking about just cutting the existing brackets, and buying a riser card, but it would block all other PCI slots. So if you don't have any other sound cards, or PCIe memory, you can consider that. Or else, I'm sending as a video a mod that someone did to a Define S. You can cut the res mount between the pcie brackets and the side panel, and mount it there as in the video.
https://www.youtube.com/watch?v=zoR6VlDzQUA&t=395s
Code-name Nyx: R7-3800X w/ Scythe Fuma 2 Rev. B | Sapphire RX 5600XT | Gigabyte B550i Aorus Pro AX | Patriot Viper 4 Blackout | 3TB NVMe Storage| Cooler Master NR200 | Kubuntu/Windows 11 | Xiaomi Mi Curved 34" | Keebwerk Mega | Logitech G602 | Audio Technica ATH-M40X| Edifier e25 Luna
