Building rig right now
Go to solution Solved by tarfeef101,
5 minutes ago, Amer said:
So I've put in the mobo, cpu, ram, gpu, and now I'm about to put in the h115i. I have a phantom 820 and honestly i have no idea how to install this. I've seen videos where people remove the 200mm fan on top as well as the filter and put the radiator there for a clean look. Can someone help me by telling me how I should install it :/.
Yeah, remove that top fan and put it in the top. just screw the fans into the bottom of the rad, and screw the rad into the case from on top
Cheese
https://linustechtips.com/topic/700565-building-rig-right-now/
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
https://linustechtips.com/topic/700565-building-rig-right-now/#findComment-8958336
1 minute ago, VerticalDiscussions said:
Wise words from a purple hue mega computer :o
It's really not that big...
And for the next 31 days it's actually green and red. Roommates wanted a tree, but that's not techy enough for me.
https://linustechtips.com/topic/700565-building-rig-right-now/#findComment-8958381
Its bigger than my Corsair C70 right xD?
Also, that may be the most stylish christmas steel block your mates will ever see lmao.
*AHEM* Aluminum thank you very much...
Lol thanks, and yeah it is bigger than the average mid tower, but not by too much even. Shorter, but wider.
https://linustechtips.com/topic/700565-building-rig-right-now/#findComment-8958394
Just now, tarfeef101 said:
-snip-
I was afraid youd say aluminium is too cheap xD!
Alright then, you take care of that thing, because im sure it appreciates you being around it very oftenly :P
Groomlake Authority
https://linustechtips.com/topic/700565-building-rig-right-now/#findComment-8958400
Did you make a PCPP for that build? Like a completed build? I'd love to see the full specs and maybe more pictures
EDIT: never mind I found it on your profile :)
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
https://linustechtips.com/topic/700565-building-rig-right-now/#findComment-8958407
Thanks guys, appreciate it! yeah, I windex it about every week, every couple I clean out the filters, wipe down the interior for what leaked through
https://linustechtips.com/topic/700565-building-rig-right-now/#findComment-8958513
